Field Mapping
The custom MOS object mapping is a setup which extracts field values from foreign MOS objects and translates these into Viz Mosart fields. This is done in the newsroomsettings.xml configuration file. This simplifies integration, as no new code needs to be deployed.
The Tool Set
Default configurations are available as part of newsroomsettings.xml file
Select content from XML using simple XPath 1.0 expressions
Concatenate the XPath result using a separator
Replace parts of the result using static or dynamic variables
Apply conversion rules for the specific field type
What to Configure
Reuse or modify existing MOS field mapping in newsroomsettings.xml
Add MOS Id map entry using newsroom settings editor
Newsroom alias: MOS Id of foreign item
value: Field mapping entry name
appendContent: appends the complete MOS object to the internal Viz Mosart <item /> as a _<content /> _sub child
embeddedMosartItem: signal if the item has a Viz Mosart item embedded
Target Fields
Target fields is a list of the fields used when controlling a video server or graphics element(s).
Video Server
clip_hirespath: The name or ID of the video file
clip_description: A human-readable description of the video file [optional]
clip_dur: The duration of the video file
clip_mark_in: The start frame of the video file [optional]
Graphics Systems
graphics_id: The ID of the graphics item
graphics_description: A human-readable description of the graphics item
tc_in: Planned in time for the item relative to the parent item
tc_dur: Planned duration for the item
graphics_profile: The graphics concept context this item should be forced to play in. This value will be forwarded to graphics systems supporting concepts for graphics when cueing and playing an item.
graphics_category: Used in CG Take Out Logic to identify graphics that should be kept at story item transitions. If not set, graphics_id is used for identification.
channel: The channel to play the item, ie. DSK, WALL etc.
take: MANUAL or AUTO. If MANUAL then tc_in will be 0 and only tc_dur will be used.
outBehaviour:
TIMECODE = the element will be taken out relative to the current primary element using tc_dur
BACKGROUNDEND = the element will be taken out when switching primary story element
STORYEND = the element will be taken out when switching from one story to the next
OPENEND = the element will be taken out when reloading the rundown or by manually taking the element out
auto_continue: true/false (p.d. only for Orad, to send PlayWithoutPause command)
Mapping Source Fields to Target Fields
The following mapping <mosmap id=”VENDOR” elementtype=”CLIP”> </mosmap> contains the attribute descriptions:
Id: Value used in the MOS map section of the newsroomsettings.xml
Elementtype: CLIP for video servers, GRAPHICS for graphics systems
And <fieldmapping /> contains the attribute descriptions:
fieldname: Viz Mosart target field name
mospath: A simple XPath 1.0 expression to the location of the source value
separator: Value used for joining multiple returned values for the mospath
fieldtype:
FIELDS – the source value is in video fields
FRAMES – the source value is in video fields
TIMECODE – the source value is in time code format. Use mask attribute to identify format
STATIC – the value for the fieldname has no mospaths and should be as defined in the value attribute
REPLACE
ADJUST
value: The value to use if fieldtype is STATIC
valuetype: TEXT,TIMECODE
mask: Value on time code format for, i.e. hh:mm:ss or hh:mm:ss:ff
mustexist: Set to true if the Viz Mosart field should only be added if a non-empty value exists
regex: Regular expression used on the value. Use this to extract parts of the value from the MOS object
matchindex: Group index of the result from the regex
overwrite: if true, overwrites if a field already exists. Default is false.
Example - Video Server Item
This example is of a Quantel video item.
<mos> <itemID>3</itemID> <itemSlug>New Row 3 CVD 1-3</itemSlug> <objID>15160::559</objID> <mosID>QUANTEL</mosID> <mosAbstract>Flug über die Alpen fertig2 1:00</mosAbstract> <abstract>Flug über die Alpen fertig2 1:00</abstract> <objDur>1500</objDur> <objTB>25</objTB> <objSlug>Flug über die Alpen fertig2</objSlug></mos>Note: The objID is constructed from two numbers where the first is the Quantel clip id. The second number is the Quantel zone
<mosmap id = "QUANTEL" elementtype = "CLIP" idasindex = "false"> <fieldmapping fieldname = "clip_hirespath" mospath = "//objID" regex = "^\d+"/> <fieldmapping fieldname = "clip_description" mospath = "//objSlug"/> <fieldmapping fieldname = "clip_mark_in" fieldtype = "static" value = "00:00:00:00" valuetype = "TIMECODE"/> <fieldmapping fieldname = "clip_dur" fieldtype = "FIELDS" mospath = "//objDur" valuetype = "TEXT"/></mosmap><fields> <field name = "clip_hirespath" value = "15160"/> <field name = "clip_description" value = "Flug über die Alpen fertig2 1:00"/> <field name = "clip_mark_in" value = "00:00:00:00"/> <field name = "clip_dur" value = "750"/></fields>Example - Graphics Item
This example is of an XPression graphics item.
<mos> <itemID>11</itemID> <objID>{01E4E214-2414-4C71-956F-6587E3FD1E4B}</objID> <mosID>XPRESSION</mosID> <mosAbstract>MAIN KEY Name (B2B): This is a test | Test</mosAbstract> <itemChannel>1</itemChannel> <itemEdStart>0</itemEdStart> <itemEdDur>0</itemEdDur> <itemTrigger>CHAINED</itemTrigger> <macroOut>NONE</macroOut> <mosExternalMetadata> <mosPayload> <gfxtype>CG</gfxtype> <itcTimeIn>500</itcTimeIn> <itcTimeDur>250</itcTimeDur> </mosPayload> </mosExternalMetadata></mos><mosmap id = "XPRESSION" elementtype = "GRAPHICS"> <fieldmapping fieldname = "graphics_id" mospath = "(//itemID | //objID)" separator = "-" fieldtype = "REPLACE" value = "{STORYID}-{MOSPATH}"/> <fieldmapping fieldname = "graphics_description" mospath = "//mosAbstract"/> <fieldmapping fieldname = "tc_in" fieldtype = "FRAMES" mospath = "//itcTimeIn" valuetype = "TEXT"/> <fieldmapping fieldname = "tc_dur" fieldtype = "FRAMES" mospath = "//itcTimeDur[text()!='0']" valuetype = "TEXT"/> <fieldmapping fieldname = "outBehaviour" mospath = "//macroOut"/> <fieldmapping fieldname = "channel" fieldtype = "STATIC" mospath = "//gfxtype[text()='CG']" value = "DSK" valuetype = "TEXT" mustexist = "true"/> <fieldmapping fieldname = "channel" fieldtype = "STATIC" mospath = "//gfxtype[text()='OTS']" value = "WALL" valuetype = "TEXT" mustexist = "true"/> <fieldmapping fieldname = "channel" fieldtype = "STATIC" mospath = "//gfxtype[text()='FS']" value = "FULL" valuetype = "TEXT" mustexist = "true"/> <fieldmapping fieldname = "channel" fieldtype = "STATIC" mospath = "//gfxtype[text()='OTHER']" value = "FULL" valuetype = "TEXT" mustexist = "true"/></mosmap><item> <fields> <field name = "graphics_id" value = "VER7ENPS1;P_VANLAB\W\R_F3144D55-78F2-494B-863ED060A74D92F7;D02D7434-58BB-43D6-B03601E7B7BBC1E7-4-{1ECA795F-101D-4301-A559-2A1392F3AA2D}" fieldtype = "TEXT"/> <field name = "graphics_description" value = "BANNER:Chan1: | Manual | Timed(---):TIMED" fieldtype = "TEXT"/> <field name = "tc_in" value = "" fieldtype = "TEXT" inputmask = "ff" default = "00:00"/> <field name = "tc_dur" value = "125" fieldtype = "TEXT" inputmask = "ff" default = "00:00"/> <field name = "outBehaviour" value = "TIMED" fieldtype = "TEXT"/> <field name = "channel" value = "DSK" fieldtype = "TEXT"/> </fields></item>
