Template Editor Password
Password protection can be enabled for the Template Editor. If enabled, the user will be prompted for the password when opening the Template Editor.
By default, no protection is enabled, and the user is not asked for a password before opening the Template Editor.
Add or Change Password
To enable password protection in AV Automation, select Devices > Change Password.
In the Change password dialog box that opens, a password can be set or an existing one changed.
Reset Password
If the password is lost, it can be reset by opening AV Automation Settings (press CTRL+SHIFT+S while AV Automation has focus). Find the PasswordHashed entry, and remove the value.
