Settings Editor - MOS
To open the frmSettings XML Editor, open the Manus Administrator console, then type settings followed by <ENTER>.
Open sub-sections by clicking the section headers:
Configuration
Auto preview overlays: List of graphics destinations supporting preview of overlay graphics. I.e. DSK will enable preview of all overlay graphics with handler=DSK. Default: Empty (no preview)
Auto take offset: Value of an offset for the autotake function. Default: 0 (milliseconds)
Default Handler Name: For all graphics that have no handler name, a default one will be assigned, and this can be configured using DefaultHandlerName setting in Manus Administrator. Default: DSK
Default Lower Third Out Behaviour: Default: TIMECODE
Force clip editorial time: Always show Editorial time in GUI. Default: False
Frame rate: Frame rate of the system. Valid rates: 25, 29.97, 50 and 60. Default: 25
Ignore initial synchronization: Will ignore all roReq on startup when synchronizing with NCS. Default: False
Ignore sending item status filter: List of regular expressions used to prevent sending MOS status back to NCS. The regular expressions are matched against MosIds of MOS objects. Set to ‘*’ to disable the sending status for all mos objects. Default: Empty (send status for all mos objects).
Ignore updates if nothing changes: If set, will ignore story update from NCS if the updated story is assumed to be equal to the current version of the story. Default: False (no NCS story updates are ignored)
Item status unavailable values: List of status values used to identify NCS content as invalid. Content as graphics or clip objects. Default: NOT_READY, ERROR
Keep story status on updates from NCS: Enable this to keep played out stories gray if the story is updated in the NCS. Default: False
MetaData creator priority: Select between Newsroom editorial time, MAM duration or full video clip length. Separate IDs with commas. Override the priority of where the timing information of a video file is taken from. Use the name of the Media Administrator entry. Special names are NCS (for information from the NCS) and GLOBAL (global values from media object). If empty, Viz Mosart will insert NCS as the first and GLOBAL as last entries. Default: Empty
Min. time between story update: If no update is received from the NCS within the given minimum time, Viz Mosart will force a story update. Default: 1000 (milliseconds)
Minimum clip length: This value sets the minimum visible length of an offline clip in a story in the GUI. As soon as Viz Mosart receives clip information, the visible length will be updated. Default: 5 (ss:ff)
Network exclude: Manus Administrator will automatically enter idle mode on network failure. This property is a CSV list of network names to ignore when monitoring networks. Default: Empty (monitor all networks)
Network include: Manus Administrator will automatically enter idle mode on network failure. This property is a CSV list of network names to monitor for network failure. Default: Empty (monitor all networks)
Offset secondary events with mix delay: Secondary events will follow primary events mix delay. For example, a lower-third element will be delayed the same mixdelay as the package it is supposed to be keyed on. Default: False
Pause Timing On First Break: When enabled any first story with a single break template will not start the rundown timing (Elapsed rundown duration). The timing will start when the next story is taken. Default: False
Preload Accessory Cue Delay: Defines the delay between end of cue the next item and when a pending preload/pretake accessory shall be executed. Time given in frames. Default = 6 frames, i.e. the accessory preload/pretake functions shall take place after the cue operation is done in AvAutomation with an additional and configurable delay of PreloadAccessoryCueDelay frames.
Read Speed: Number of words read per minute by the anchor. (By default, words are taken to be the parts of text separated by space characters. See the setting Use character for read speed word below.) This is applied to prompter text to determine the duration of an announcement and thus the length of the green camera bar and the green part of the voiceover bar in the Viz Mosart GUI. Default: 145 (words per minute)
Note: Note: This is a fallbackreadrate which is only used when the NCS System fails to provide a ReadRate of its own. This function can be tested by changing any readspeed=”xx” to readspeed=”” on an item in a local Manus file.
Reset AutoTake on 'Clear Loop': Enable this to automatically disable the autotake mode when using the clear loop function from the GUI. Default: True
Server description: The description of the server is used for display only. Will be displayed in Timing Display. Default: ControlRoom
Startup in idle mode: Whether the Manus Administrator will be idle at start-up. Default: True
Story Compare Ignore Attributes: Used for debugging purposes only. Default: Empty
Story Scope: Specifies the story scope. Default: Empty (Single). Either:
Single = A single story uses one row in the Viz Mosart GUI
Grouped = A single story may span over a sequence of rows in the Viz Mosart GUI
Currently only supported for ENPS where in “Grouped” mode ENPS stories with same story name but different story segment is treated as the same story in Viz Mosart.
Templates allowing graphic pretake: List of template types that will allow pretake of overlay graphics elements. Available template types: ADLIBPIX, BREAK, CAMERA, DVE, FULLSCREENGRAPHICS, LIVE, PACKAGE, TELEPHONEINTERVIEW, VOICEOVER. Default: PACKAGE, VOICEOVER. Default: PACKAGE, VOICEOVER
Use character for read speed word: If True, each character will count as a word for the purpose of calculating the spoken duration of prompter text, cf. the setting Read Speed above. This can be useful in languages like Chinese and Thai, where the space character is not used to separate words. If False (the default), words are separated by space characters. Default: False
Use Take Out Logic: Enables the CG takeout logic. When two CG graphic objects with the same graphic IDs are next to each other, the first one is not taken out, only “take in” on the second object will be executed. When True, enables the takeout functionality for overlay graphics. Default: False
Configuration File Paths
AvConfig: The path to the XML-file containing the audio and video mappings defined in the AV Automation application. Default: c:\channeltemplates\avconfig.xml
Channel templates: The path to the file containing the Viz Mosart templates built in the AV Automation Template Editor. Default: c:\channeltemplates\channeltemplates.xml
Manus directory: The path to the folder containing copies of the internal Viz Mosart rundown. Default: c:\manus
Newsroomsettings: The path to the XML file containing the mappings from newsroom system commands to Viz Mosart templates. Default: c:\channeltemplates\newsroomsettings.xml
Crossover Configuration
ConnectionString [CrossoverClientConnectionString]: The connection string of the crossover, example: controller=IP address, client=crossover. Default: Empty
Crossover Auto Take On Switch Offset. Offset in milliseconds to pre-take an autotake when the next story item is after a crossover switch. Positive value will trigger the autotake before the given duration of the story item. Negative value will trigger the autotake after the given duration of the story item. Default: 0
Crossover Set Next On Switch Delay: Delay of sending setnext story from the server running the show when taking control. Default: 500 (milliseconds)
Default Item Durations
Break: The minimum length given to the BREAK template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 100 (milliseconds)
Camera: The minimum length given to the CAMERA template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
DVE: The minimum length given to the DVE template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
Full-screen-graphic: The minimum length given to the FULLSCREEN GRAPHIC template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
Item: The minimum length given to any template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 100 (milliseconds)
Live: The minimum length given to the LIVE template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
Lower-third: The minimum length given to the Lowerthird template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
Telephoneinterview: The minimum length given to the PHONO template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
Video clip: The minimum length given to the CLIP template type in the rundown. If no time is given in the NCS, then this time will be given to the element. Default: 125 (milliseconds)
INews Web Service Configuration
Web Service Connection: Example: WebServiceServer=localhost;iNewsServer=10.211.112.104;iNewsUsername=mosart;iNewsPassword=mosart;SendUpdatesStatusForAllItems=true;ClearStatusWhenRundownReloaded=true. Default: Empty
Logging
Ignore verbose events filter: Semicolon based list of events to ignore in the log when using verbose logging. Default: Empty (log all events)
In use: Enables or disables the logging of events from the Manus Administrator to the log file. Default: True
Log level: Sets the detail level of logging to the log file. 0=normal, 1=warnings, 2=errors, 3=info, 4=detailed. Default: 0
Mos communication is logged: Enable logging of the communication to and from NCS. Default: False
MSMQ Log limit: Value to identify when the application should dump the log queue to file. Default: 4023
Pass verbose events filter: Semicolon based list of events to log when using verbose logging. Default: Empty (log all events)
Path for MMLog: The path where the Viz Mosart log is stored. Default: MosartLog
Trace internally: Enables or disables internal tracing to console for debugging only. Default: False
Use verbose logging: Enables or disables verbose logging. If UseLogging is set, verbose increases the details sent to the log. Default: False
WTC Level: Sets the detail level of logging to the console. 0=normal, 1=warnings, 2=errors, 3=info, 4=detailed. Default: 4
Manus Configuration
Default Manus: This value selects the default rundown to use. The special READYTOAIR value selects and uses all rundowns indicated by the newsroom system as ready to air. Default: READYTOAIR
Manus expiration time: Time in days to keep Manus Administrator files. Files older than the ManusExpirationTime will be deleted when Manus Administrator is started. Default: 0 (no clean up)
Manus keep file pattern: If ManusExpirationTime is given this property, allows a list of file search patterns for files to keep in the Manus Administrator directory. Default: Empty (no files to keep) i.e. "TEST*;DEMO??.xml" will keep all files starting with “TEST” and all DEMO??.xml files where ‘?’ denotes a wild character. Note ‘;’ (semicolon) is used to separate the file search patterns.
Use the default selected manus: When enabled will automatically initialize the rundown given in the DefaultManus setting. Default: True
Misc
ItemIdGenerator: Default: Empty
Mosart generates internal IDs using a combination of rundown, story and item IDs. Some newsroom systems reuse item IDs between story updates, thus if a new object is inserted before an old object, Mosart will generate the same ID for the new object as the old object had, and the old object will get a new ID. A custom ID generator can be assigned by setting the ItemIdGenerator property in Mosart Server settings.
Value
Description
(Empty)
This is the default value and uses the default ID generator
ItemAndObjectID
This ID generator appends the object ID to the default ID generator. This setting should be used for Dalet Newswire.
NCS Configuration
Forced Mos protocol version: Protocol version to use in NCS communication. Default (blank) setting will detect the version from the NCS, otherwise, use "2.8.3", and so on. Default: Empty
Ignore Send Cue Status To NCS For Offline Clips: Enable this flag to prevent the NCS for receiving CUED or READY statuses of offline video clips. Default: False
Lower Port: The MOS protocol communicates on three ports; lower, upper and top. MosUpperPort is MosLowerPort + 1 and MosTopPort is MosLowerPort + 2. Default: 10540
Mos server timeout: Timeout information for MOS ports. Default: 0.0.0.0
1. NCS to Mosart Lower port: NCS heartbeat sent to Viz Mosart. If the time between received heartbeats exceeds the value, the connection is displayed lost. Value=0 means no timeout. Default: 0 (seconds)
2. NCS to Mosart Upper port: NCS heartbeat sent to Viz Mosart. If the time between received heartbeats exceeds the value, the connection is displayed lost. Value=0 means no timeout. Default: 0 (seconds)
3. NCS to Mosart High port: NCS heartbeat sent to Viz Mosart. If the time between received heartbeats exceeds the value, the connection is displayed lost. Value=0 means no timeout. Default: 0 (seconds)
4. Mosart to NCS: Viz Mosart to NCS timeout. If the time from heartbeat is sent to response is received exceeds the value, the connection is displayed lost. Value=0 means no timeout. Default: 0 (seconds)
MosId: MOS identification of this instance of the Manus Administrator. Generic value is mosart.<galleryID>.<stationID>.mos. Default value: mosart.mos
NCS Time Zone: Used when the time zone is not indicated by the NCS Server. Other values can be +/-hh[:mm], where hh and mm are two digits hours and optional minutes. Default: Z (UTC) unless another value is specified
NCS Type: Generic: No special handling of native NCS commands. Generic, DaletPlus, ENPS, NcPower, Octopus, Open Media and MOSInews. Default: Generic
NCSId: Same form as mosID, but this value is the ID for the newsroom system. See Notes below. Default: NCSSERVER
NCSId Backup: Same form as mosID, but this value is the ID for the backup newsroom system. See Notes below. Default: Empty
Newsroomtag keep keywords: Default: Empty
ReadyToAir by default: If the value is true, all MOS active rundowns will be assumed to be ready to air. Default: False
Refresh Media On NCS Update: Setting to true will trigger clip refresh for all clips that belong to a story being updated, normally via story updates from NCS. This ensures that all clip information is synchronized. Default: False
Reply with connection MosId: If set, any MOS message sent to the NCS will use the connection MosId instead of the current mos object ID. Default: False
Schema: The string is used to identify Viz Mosart items in the rundown. Default: http://www.mosartmedialab.no/schema/mositem.dtd
Server: IP address or hostname of the main newsroom system’s MOS gateway. See Notes below. Default: NCSSERVER
Server BackUp: IP address or hostname of the backup newsroom system’s MOS gateway. See Notes below. Default: Empty
Template feedback to NCS:
Enabled: Enables sending templates to NCS through MOS communication. Default: True
GenerateUniqueObjId: Default: False
GroupedByType: Enable to send all template types as one MOS object with the variants embedded in the objects. Disable to send all template variants as separate MOS objects. Default: False
MergedClips: Whether PACKAGE and VOICEOVER templates will be merged as CLIP templates. Default: False
SendAllTemplateSets: Enable to send templates from all template sets to the NCS. Disable to send only the default template set. Default: False
TemplateChangeWanted: Default: False
Use NCS backup server: Enables the NCS backup configuration. Default: False
UseItemStatusToNCS: When enabled, Viz Mosart will send roItemStat/roElementStat messages to the NCS when clip updates are received from the Media Administrator. If the clip is available on the playout server, READY is sent. Otherwise NOT READY is sent. Default: False
Template Database Configuration
ConnectionString: The connection string for the Template DB. E.g. for MySQL: server=<hostname>;User Id=<user>; Password=<password>;database=mosarttemplatedb. Default: server=localhost;User Id=root;database=mosarttemplatedb
Default inserter: The name to be used for the …_insertedby and …_updatedby columns. Default: inserter
Provider name: The provider name for the Template DB. E.g. MySql.Data.MySqlClient for MySql. Default: MySql.Data.MySqlClient
Use template database: When True enables the Template DB functionality, i.e. exporting template type aliases from DB to newsroomsettings.xml at startup, and importing from newsroomsettings.xml to DB after saving newsroomsettings.xml. Default: False
Note: Enter the TemplateDbConnectionString before enabling ‘UseTemplateDb'
Notes
If there is more than one main newsroom system, the settings parameters MosServer, MosServerBackup, ncsID, and ncsIDBackup should contain space separated lists of values, and the values must be in the same order.
If some of the newsroom systems do not have a backup system, put them last in the list and leave the corresponding values blank for MosServerBackup and ncsIDBackup.
If two newsroom systems are backup for each other, both must be listed both as main and backup, and if one system is backup for more than one main, it must be listed as backup for each of them.
If different newsroom systems need to give Viz Mosart different MOS IDs, the settings parameter mosID should also be a space-separated list of values, in the same order as for ncsID.
Only one space between list values, and all values are case sensitive.
