AV Automation Devices - Camera Robotics
Use Robotic Cameras: Check to enable the robotic camera control functionality.
Robotic Camera: CAMEROBOT, CINNEO, FX-MOTION, PANASONIC, SHOTOKU TR-T, SHOTOKU TR-T IP, TECHNODOLLY, TELEMETRICS, VINTEN 200, ELECTRIC FRIENDS
Host: Hostname or IP address of the RCC (Robotic Camera Controller) server.
Hosts (FX-Motion and Technodolly): A comma separated list of names or IP addresses for the camera robots starting from Camera 1. Missing robots are indicated by extra commas.
Port: Port to communicate with the RCC server.
Com port: For serial communication with the RCC server.
Note: When using PANASONIC you must select the Com port to use. Only one controller can be connected to each Com port. -
Cameras: List of robotic cameras for individual stand-by control. List members are separated by commas, or by hyphens indicating ranges.
Note: When using PANASONIC the connection goes through a controller. The Cameras value is used to set the controller, so only enter one number here.
