ActiveX Configuration
The ActiveX is used to insert Viz Mosart template information into the Newsroom System script.
For the ActiveX to function correctly, some parameters are required to be set that link the ActiveX content to your Viz Mosart Server installation.
The ActiveX can be linked to the Viz Mosart Server either via the Mosart Viz Mosart Template Database, or directly to the Viz Mosart Server.
This section contains:
