How to Set Up Audio Player
Install Audio Player, then start it.
Open AV Automation
Go to Devices > Preferences > Audio > Sound player
Check Use sound player and choose Mosart Audio Player
Under Host write the IP address to the computer where Audio Player is running.
Under Default directory write the folder path where the audio files that will be used is stored.
Restart AV Automation and check that the connection is green.
