Plug-ins User Guide
Text Parameters
images/download/thumbnails/114312700/ico_textp.png
The Text Parameters plug-in offers the designer the possibility to animate text parameters, as standard text parameters in the Text Editor cannot be animated. The parameters for the Text Parameters can only be used for animation.
The settings are not visible on the text until an animation update has been made.
Text Parameters Properties
  • Use Kerning: Enables or disables the use of Kerning.
  • Tracking: Sets the space between each letter.
  • Leading: Sets the space between each line of text.
  • Word Spacing: Sets the space between each word.
  • Use Soft Shadow: Enables the use of Soft Shadow. Level 4 is the most blurred, softest shadow. The Drop Shadow option must be enabled for the Soft Shadow to be visible.
  • Use Drop Shadow: Enables or disables Drop Shadow.
  • Direction: Sets the direction of the Drop Shadow in degrees.
  • Distance: Sets the distance of the Drop Shadow.
  • Z Offset: Sets the offset of the Drop Shadow in the Z-axis.
  • Color: Sets the color of the shadow.
