Plug-ins User Guide
Hops Manager
The Hops Manager plug-in controls multiple instances of several plug-ins from one interface. The plug-in should only be used if all parameters for the control plug-ins are the same. If for any reason different values are needed, the plug-in should not be used.
The plug-in controls the CWMClient plug-in, Map Pyramid plug-in and NavFinder plug-in; however, only instances which are part of a hop are controlled. The plug-in has two main options; global values and hops.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps_Man
Hops Manager Properties
Global Values
Global values are used in order to update values globally on all control plug-ins.
Under the global values tab all parameters are the same as those found in the actual plug-ins you want to control. For more information see:
Hops
Hops are used to jump to a specific hop. From this tab you can select and refresh a map and fine tune pan values from NavFinder.
Multi Hop: Opens the Multihop Editor in the World Map Editor when the Multihop button is pressed.
