Plug-ins User Guide
Installing DataPool
First-time Installation
  1. Run the installation file and follow the instructions. When installing DataPool for the first time three installation types are available:
    • Typical: Installs only the DataPool plug-in group.
    • Custom: Installs the plug-in groups that the user selects.
    • Full: Installs all the DataPool plug-ins (all the groups).
  2. Select the installation type and continue. An information window displays the path of the installation and selected plug-in groups.
    Note: The plug-ins are installed to the plug-in directory under the latest Viz installation.
    Note: This User Guide is installed with the DataPool group.
To Upgrade an Existing Installation
  1. When upgrading the installation three options are displayed:
    • Modify: Changes the installed groups on the machine.
    • Repair: Reinstalls the installed groups (*.dp files are not overwritten).
    • Remove: Uninstalls DataPool.
  2. Select one of the options and click the next button.
