Plug-ins User Guide
Text FX Jitter Position
The Text FX Jitter Position plug-in creates an jittering motion of the characters by randomly changing the position of each character. The degree of position change and the starting sequence of the jittering can be altered. To use the function add it onto a container which holds a font. To create an animation, animate the progress. Other values can of course be animated as well.
Supported Pipelines |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Jitter Position Properties
Use Axis: Defines on which axis or axes the characters moves to create the jittering effect.
Lock Axis: Sets Range and Randomness to the same value for all axes when enabled. If you disable it, Range and Randomness for each of the axes are shown and you can set them individually.
Range: Sets the range of the jittering movement.
Randomness: Sets the intensity of the jittering movement.
