Plug-ins User Guide
External Interface
The external interface to DataPool is based on Viz messages sent to the DataPool plug-in. Each message contains a series of data assignments to different DataFields.
The structure of the message is:
command1 command2 command3 ...The structure of each command is as follows:
<Name>[items range] = datum1, datum2, datum3, ...; Where name is the name of the DataField to assign data to and items range is a description of items to which the data is addressed.
Note: The semicolon is part of the command and should be added at all times. It is used to define the end of the command.
The item ranges are a comma-separated list of indexes, or a from-to index.
Examples
Send data to a field named VALUE:
VALUE=30; -
Send data to the first five values of a field called VALUES:
VALUES[0-4] =0,1,2,3,4;The above is equivalent to sending:
VALUES[0]=0; VALUES[1]=1; VALUES[2]=2; VALUES[3]=3; VALUES[4]=4;Note: The indexes of the items are zero-based (start from 0).
Send data to the items 1-3, 55-57 and 101:
VALUES[1-3,55-57,101] =0,1,2,3,4,5,6;This is equivalent to sending:
VALUES[1]=0; VALUES[2]=1; VALUES[3]=2; VALUES[55]=3; VALUES[56]=4; VALUES[57]=5; VALUES[101]=6;
