Plug-ins User Guide
Text Auto Scale
The Text Auto Scale plug-in automatically scales text within a Text Box area as defined in the Text Editor.
Text Auto Scale Properties
Enabled: The plug-in is enabled by default when added to a container. Click the button to disable.
Default x-scale: Sets the default scale value for the X-axis.
Default y-scale: Sets the default scale value for the Y-axis.
Tip: When using the Text Auto Scale plug-in, Text Box scaling should be set to Off to avoid conflict in scaling operations.
