Plug-ins User Guide
Map Layers
images/download/thumbnails/57216861/mapl_ico.png
The Map Layers plug-in exposes map layers to an external application. Map layers are labels, regions, and so on.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps
Map Layers Properties
  • Mode: Defines the layer maps mode Static and Dynamic.
    • Static: Enables maps to be imported to Viz Artist’s image library and saved with the scene.
    • Dynamic: Enables pyramid maps to be loaded from the cache and temporary folder. When the CWMClient plug-in receives a new map, all layers are updated.
  • Texture Compression: Sets the compression level for the texture (DTX5 is the highest compression level, which is less texture quality).
  • Texture Quality: Sets linear for using the same image resolution in the entire zoom range, or Mipmap to change resolution according to the distance from the image (managed automatically in Viz Artist).
  • Texture Mapping: Defines how the texture (map) is mapped.
  • Texture Anisotropic Filter: Turns on the relevant anisotropic in the image on the same container with CWMClient (similar to Mipmap, above). Available settings are Off/2x/4x/8x/16x.
  • Edited Layer: Sets the layer number for editing. Each layer is then assigned map properties to display.
  • Active: Activates or disables the selected layer.
  • Container: Assigns the container for holding the created layer map.
  • Flags: Enables (On) the requested property to expose the map property or feature in the selected layer. Flags refer to all the settings from Base Map to Overlay Data.
  • Build Tiles: Builds the map layers.
