Plug-ins User Guide
Text FX Vertex Explode
The Text FX Vertex Explode plug-in allows you to create an effect where text characters are exploded with a vertex effect.
Supported Pipelines |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Vertex Explode Properties
X, Y and Z Distance: Defines direction and distance of moved text.
Show Direction: Enables and disables view of movement vector.
