Plug-ins User Guide
Control Hide in Range
images/download/thumbnails/114312317/ico_chir.png
The Control Hide in Range plug-in hides or shows a container if the input value given by the user is within or outside a specified value range. The input value must be from a font container that holds a numeric value, typically with a Control Num plug-in.
Control Hide in Range Properties
  • Input Value: Shows the current input value.
  • Lower Range Bound: Sets the upper bound for the range.
  • Upper Range Bound: Sets the lower bound for the range.
  • Visibility in Range: Sets whether the container should be visible or hidden when the input value is within the range.
