Plug-ins User Guide
Text FX Emoticons
The Text FX Emoticons plug-in allows you to create an emoticon container, add it to the Emoticons plug-in and replace characters (tokens) in a text string with an assigned container.
Supported Pipelines |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Emoticons Properties
Autoscale: Scales the emoticon containers so their height above the baseline (0) is identical to the height of character A.
UTF-8 Encoding: Enables UTF-8 encoding for the text effect.
Token 1 - n: Sets the placeholder for an emoticon.
Container 1 - n: References the container holding the emoticon. The container should be similar to the layout of a glyph.
Precache 1-n:- Enables Viz Artist/Engine to cache the objects.
