Plug-ins User Guide
Control Bars
The Control Bars plug-in allows binding of tab field values to the Bar Value fields in the Bar values presenter plug-in. Each bar value property in the Bar Values editor is presented as a separate tab field in Viz Trio.
Control Bars Properties
First Bar Field ID: Sets the tab-field ID for the first Bar value.
Last Bar Field ID: Sets the tab-field ID for the Last Bar value.
Expose Bars Max/Total Value: Exposes the Bars Max/Total value as a separate tab field when enabled.
