Plug-ins User Guide
Slide Show
images/download/thumbnails/114312685/ico__sshow.png
The Slide Show plug-in allows you to create a sequence where a group of containers fade in and out one by one in the same manner as a normal slide show.
Slide Show Properties
  • Blend Value: Controls the slide show sequence. Animate this value to create the change from slide to slide.
  • Use Offset: Enable this option if the slides have the same initial position and you want them to move along some of the axes as the slides are being shown.
  • X, Y and Z Offset: Sets the offset values of each slide calculated form the one previously shown.
  • Fade Out: May be set Off, On (every slide) or Last (last slide only)
  • Start with: Sets what should be visible if slide show is not started.
To Create a Slide Show
  1. Add a group to the scene tree, and name it slideshow.
  2. Add a number of Sub-Containers that are used to house the slide(s).
  3. Add the Slide Show plug-in to the slideshow container.
  4. Position the Sub-Containers in advance using the transformation editors for each container, or open the Slide Show editor and offset them to create a moving sequence.
  5. Animate the blend value to create the slide show sequence.
  6. Click the Initialize button to initialize the plug-in. Each of the Sub-Containers automatically get an alpha icon.
