Plug-ins User Guide
Control Clock
The Control Clock plug-in allows the user to set time for a clock as well as controlling several clock functions. The clock object is a text container in the scene with the clock function enabled.
Control Clock Properties
Expose Limit: Enables the user set a limit for the clock.
Expose Direction: Enables the user to choose the direction for the clock.
Action: Sets the clock action that is the default value in the control client’s clock editor.
Input Value: Shows the current value for the plug-in. It is not necessary to set any value here. It is normally only used for debugging purposes.
