Plug-ins User Guide
Control DP Object
images/download/thumbnails/114312375/ico_cdpo.png
The Control DP Object allows copying or linking of Data Pool objects.
Control DP Object Properties
  • Input value is: Select from Object to COPY, Object to LINK or Direct VALUES
  • Input value: Shows the current input value.
