Plug-ins User Guide
CFX Scale
The CFX Scale plug-in allows you to create a scaling animation of the containers.
Note: This plug-in is located in: Plugins -> Container plug-ins -> ContainerFx
CFX Scale Properties
Anchor Horizontal: Sets the anchor point for the containers on the horizontal plane.
Anchor Vertical: Sets the anchor point for the containers on the vertical plane.
Use Axis: Defines on which axis or axes the containers scale.
Lock Axis: Scales the Begin- and End the same way for all the axes when enabled. If you disable the option, Begin and End must be set for all axes individually.
Begin: Sets the initial size of the containers.
End: Sets the ending size of the containers.
