Plug-ins User Guide
N Quad
images/download/thumbnails/114312126/ico_nquad.png
The N Quad plug-in creates a rectangle with different attributes.
Note: This plug-in is located in: Plugins -> Geom plug-ins -> Primitives
N Quad Properties
  • Use LOD: Enables/disables dynamic level of detail.
  • Tessellation U: Sets the degree of detail.
  • Tessellation V: Sets the degree of detail.
  • Orientation: Switches the orientation from Top Bottom to Left Right.
  • Top/Left Width: Sets the width.
  • Bottom/Right Width: Sets the width.
  • Height/Width: Sets the height.
  • Depth: Sets the depth.
  • Center X: Switches the center in X between Center, Top and Bottom.
  • Center Y: Switches the center in Y between Center, Left and Right.
  • Shearing: Sets the shearing value, so the bottom is shifted.
  • Image Mapping: May be set to Stretch or Tile.
  • Crop Top/Left: Crops the top.
  • Crop Bottom/Right: Crops the bottom.
  • Border Geometry: Enables/disables the top and bottom border width parameters. When enabled, only the border outline is visible.
  • Top Border Width: Sets the width of the top border.
  • Bottom Border Width: Sets the width of the bottom border.
To Create an N Quad
images/download/thumbnails/114312126/pg_nquad_x.png
  1. Create a new group and add the N Quad plug-in to it.
  2. Add a material and/or a texture to the group.
  3. Open the transformation editor and set Rotation X and Z to -45.0.
  4. Open the N Quad editor and set the following parameters:
    • Set Orientation to Left-Right.
    • Set Top/Left Width to 200.0.
    • Set Bottom/Right Width to 0.0.
    • Set Height/Width to 300.0.
    • Set Depth to 100.0.
    • Set Center X and Y to Center and Bottom, respectively.
