Viz Mosart User Guide
Skipping a Story Element
The next story element can be skipped with the SKIP NEXT command (default F9), making them disappear from the GUI. The element following the skipped element will then be cued in preview. Skipped element actions can be reversed with the UN-SKIP NEXT command (Default: SHIFT+F9), making them reappear in reverse order. Once you have progressed beyond the skipped item in the running order it is no longer possible to bring it back with UN_SKIP NEXT.
