Viz Mosart User Guide
Exporting and Importing Keyboard Shortcuts
You can save sets of Viz Mosart keyboard shortcuts for reuse on other clients.
To Export your Keyboard Shortcuts
From the main Viz Mosart menu, select Tools > Keyboard shortcuts editor.
In the menu bar, select Layout > Export.
The file is held on the ManusAdmin server within the Viz Mosart system.
To Import Keyboard Shortcuts
In the menu bar, select Layout > Import.
These server-based shortcuts will overwrite your local shortcuts.
If desired, you can always import the server-based shortcuts (and overwrite any local definitions) when starting Viz Mosart.
Navigate to:
Tools > General settings > User interface > Keyboard > Import keyboard shortcuts on startup.
