Viz Mosart User Guide
Running the Rundown
The TAKE_NEXT command can also be mapped to any key (default F12) and will either start the rundown or move to the next story element. If the current element is the last element in a story, the TAKE_NEXT command will take the first element in the next story. When the rundown is running, the current play position within the on-air template is indicated by a red Play marker.
