Viz Mosart User Guide
Adding Stories to the Rundown
images/download/attachments/54012293/operation_story-insert-menu.png
By right clicking on the info area and selecting Edit > Insert Story, you can insert a new story-line. Content can then be dragged into the new story from the Assets and Favorites tab, or inserted using the QuickEditor.
In addition you can also remove a story, add new items into a story, change the selected story as well as removing templates from a story.
Note: If story is locked with Lock Story from NCS Update, reload of the rundown (SHIFT+F12) will delete the new story. Only Lock Rundown from menu Rundowns will prevent deletion of the new story when reloading.
