Viz Mosart User Guide
On Air Shortcut Operations
It is possible to drag and drop template elements directly onto buttons in the main Viz Mosart window. To do this, simply drag an element from the Asset or Favorites Tabs and onto a button. Using the specially defined drag and drop functionality is described in Media Pool and General Settings.
Note that on the fly buttons are saved to the keyboard setup.
