Viz Mosart User Guide
Managing NCS Rundowns
Adding iNews Rundowns
iNews rundowns can be added manually.
  • To add iNews rundowns, select Tools >Edit iNews User Rundowns.
    images/download/attachments/37578788/iNewsRundownSelector.png
Rundowns added here are also available as NCS Available Rundowns > Arrange Rundowns menu.
The menu item Edit iNews User Rundowns is only displayed when an iNews NRCS is connected to Viz Mosart.
MOS-activated Rundowns
  • The rundown menu Rundowns > NCS active displays rundowns sent to Viz Mosart from the NCS.
    A selected rundown is highlighted in orange.
    images/download/attachments/37578788/image2018-1-12_13-58-21.png
  • To show and run a specific rundown, select the entry from the Rundowns > NCS active menu.
    (Selecting a rundown from this menu is equivalent to using SHIFT+F12, which reloads the rundown).
Ready to Air Rundowns
  • A special, predefined rundown is the ready to air rundown. Selecting this menu option displays all rundowns with Ready to Air status, sorted by editorial start time.
    Any new rundowns connected to Viz Mosart, with the Ready to Air status, are added or appended to this listing.
Selecting a Rundown from the NCS
  • You select your required rundown from the Rundowns option in the menu bar.
    images/download/attachments/37578788/image2018-1-12_14-9-41.png
