Viz Mosart User Guide
Changing Template Sets
images/download/attachments/54012296/operation_studio-setup-change.png
The currently loaded template set in AV Automation can be changed directly from the Viz Mosart GUI. To do so, use the Studio Setups menu and select the desired template set from the drop-down menu.
