Viz Engine
Video Output: SHM Output
Configure Shared Memory Output channels from this panel. The shared memory output is only available on systems with non-IP Matrox video boards, or if Check Video Card is set to None in the Video Board section.
images/download/attachments/27018596/configuringviz_config_video_out_shm_output.png
  • Shared Memory Output: Set the output to Active or Inactive.
  • Color Format: Displays the active color format for the configured SHM Output.
  • Unique Identifier: Change the name of the Shared Memory if required. Used when connecting to services such as Viz Coder.
