Viz Engine
Video Input: Clip Input
images/download/attachments/27018572/configuringviz_config_clip_input.png
Use the Video Input: Clip Input panel to configure available playback channels. The number of available clip input channels is set in Video Input.
Clip Input Properties
  • Pipeline Size: Defines the number of frames Matrox’ internal clip reader buffer should buffer in advance. Default value is 20.
  • Texturemanager Size: Texture download buffer size.
  • Video Delay DVE: DVE Delay of video when used as DVE.
  • Video Delay Texture: Texture Delay of video when used as Texture.
  • VBI: Set to Active or Inactive. Defines whether VBI should be used for this channel. Default mode is Inactive.
  • Delay DVE: Sets the number of frames VBI should be delayed, before the clip can be used, in DVE mode. Default value is 0 (Off).
  • Delay Texture: Sets the number of frames VBI should be delayed, before the clip can be used, in texture mode. Default value is 1.
  • Audio: When activated, this setting enables audio for this channel. When inactive audio is disabled. Default value is Activated.
  • Delay DVE: Sets the number of frames the audio clip should be delayed in DVE mode before it can be mixed to the output. Default value is 4.
  • Delay Texture: Sets the number of frames the audio clip should be delayed in texture mode before it can be mixed to the output. Default value is 4.
  • Contains Alpha: Enables/disables playback of clips with alpha.
  • Upscale Luma: Enables/disables the default for upscale luma. Per scene setting of this value is set per clip channel under Scene Settings and Video clip options.
  • Shaped: Defines whether the fill from this channel, when the channel is used in DVE mode, should be interpreted as shaped video during DVE compositing. Default value is Inactive.
  • Repeat Mode: Determines the behavior of the video input in case of capture drops. Options are:
    • None: Does not repeat. Input goes black.
    • Field: Repeats the last field.
    • Frame: Repeats the last frame.
  • Loop Mode: Enables/disables default for loop mode. Per scene setting of this value is set per clip channel under Scene Settings and Video clip options.
  • Reverse Fields: Swaps fields when playing interlaced clips with negative playback speed (default setting). Per scene setting of this value is set per clip channel under Scene Settings and Video clip options.
  • Pending Enable: Enables/disables pending clip player for this channel. The pending clip player allows clip loading of another clip while the clip channel is still using the current clip.
  • Mode on Load Error: Determines the behavior of the current clip when loading of the pending clip fails. Options are:
    • None: Current clip mode is not changed.
    • Stop: Performs a Stop command on the current clip.
    • Pause: Current clip enters pause mode.
    • Flush: Unloads the current clip.
  • Proxy: If set to Active, video clips of a resolution different to the current configured resolution, can be played. If set to Inactive a video clip of a different resolution cannot be played.
  • Reactivation Delay: Set the minimum number of frames the texture contains black after the channel was activated to texture.
  • Ringbuffer: If set to Active the input ringbuffer is enabled when played with a NVIDIA SDI output.
