Viz Engine
NVIDIA Legacy Cards
This section details all legacy NVIDIA cards:
NVIDIA Quadro 6000
Windows XP / Windows 7 (64bit)
Viz Artist/Engine Version
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
The card supports:
  • SDI output with Matrox X.mio2
  • SDI capture with NVIDIA Quadro SDI Output card
  • G-SYNC II
NVIDIA Quadro 5000
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
The card supports:
  • G-SYNC II
NVIDIA Quadro 4000
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro 2000
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro FX 1400
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
3.0
81.67
NVIDIA Quadro FX 1500
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
3.0
162.62
NVIDIA Quadro FX 1700
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
3.0
162.62
NVIDIA Quadro FX 1800
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro FX 3400
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
3.0
81.67
NVIDIA Quadro FX 3450
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro FX 3500
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
3.0
81.67
NVIDIA Quadro FX 3700
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
3.0
162.62
NVIDIA Quadro FX 3800
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro FX 4400
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36
NVIDIA Quadro FX 4500
Windows XP
Driver
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
3.0
83.62
The card supports:
  • G-SYNC II
NVIDIA Quadro FX 4600
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
3.0
162.62
The card supports:
NVIDIA Quadro FX 4800
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
The card supports:
  • G-SYNC II
NVIDIA Quadro FX 5500
Windows XP
Driver
3.5.2
296.70
3.1.0 - 3.5.1
275.36 (or 91.36 when used with Video Wall (SDI only))
3.0
162.62
The card supports:
  • G-SYNC II
    If you experience driver problems, set use_old_nvsdk to 1 in the Viz Config file.
NVIDIA Quadro FX 5600
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
3.0
162.62
The card supports:
NVIDIA Quadro FX 5800
Windows XP
Driver
3.5.4
311.50
3.5.2 - 3.5.3
296.70
3.1.0 - 3.5.1
275.36
The card supports:
  • G-SYNC II
NVIDIA Quadro K600
Windows 7 (64bit) / Windows Server 2008 R2/SP1 (64bit)
Driver
3.6.4
341.21
