Image Mask
The Image Mask plug-in applies a mask to an image using other images (e.g. an alpha image).
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Image Mask Properties
-     Image: Placeholder for image.
-     Blend: Blends the image with the object.
-     Position X, Y %: Sets the position of the mask in percentage for the screen or object.
-     Scale X, Y %: Sets the size of the mask in percentage for the screen or object.
-     Fit: Selects the size of the image mask to the screen or the object: -     Screen: Sizes the image mask to the screen. If the object is moved, it moves while the image mask stays fixed.
-     Object: Sizes the image mask to the object. If the object is moved, the image mask moves with it.
-     Wrap: -     Repeat: Applies the image mask multiple times on the screen or object.
-     Clamp: Applies the image mask once on the screen or object.
-     Mask Aspect: Sets the aspect of the image mask to the screen or the object.
-     Invert: Inverts the image.
-     Alpha only: Enables the alpha channel for the image (for example, an RGBA image).
-     Soft Mask: Applies a soft mask (available when Fit is set to Screen).
