Working with image items
The maximum resolution of an image that can be imported and used as a texture in Viz Artist, is 16k.
To Add an Image to the Graphic Hub Database
Import Images: Images can be imported from a hard disk or a network share to the GH database (see Advanced Issues with Video Codecs).
Create a Snapshot: Images can be created through taking a snapshot of the Scene Editor.
Image Editor: In the Server Tree open an Image in the Image Editor (double-click the Image), modify (if required) and select Save as...
To Edit an Image
Double click the image to open the Image Editor.
In the Image Editor that opens, define the new settings.
Click the Save button.
To Export Images
You can export one or multiple images. Exporting RGB images with alpha creates RGBA image files.
Select the image(s) to be exported.
Open the Select Export Directory panel and select the folder where the image should be exported to
Select Export... from the Server Menu, or (when only one image is selected)
Right-click the image to be exported. In the menu that opens, select Export...
Select an image format for export.
Note: The exported image will retain its original name.
