Control Material
The Control Material plug-in exposes the material control to the Viz Trio user.
Control Material Properties
Material: Sets the path to the material that should be used when the page is imported into the control client.
Deny Browsing Upwards: When enabled, it restricts the user from browsing for materials in folders other than the selected folder and its sub-folders.
