To Create a New Scene
This will create an empty new Scene. Add containers as required in the scene tree.
Open the Scene tab (see To View items in a Folder).
Select the folder where the new Scene should go.
Open the Create New Scene panel:
Right-click in the Item List. and select Create new Scene, or
Open the Server Menu and select Create..., or
Hold the pointer over the Server Panel and press <Ctrl+A>.
In the Create New Scene panel enter a text string for the new Scene.
Click on OK.
To Import a Scene
For information about how to import a Scene (or an Archive) from a hard disk or network share to the database see Import and Archive.
To Save a Scene
Click the Save button in the lower left corner of the window, or
Hold the pointer over the Scene Tree area and press the keyboard shortcut <Ctrl+S>.
To Save a Scene with a New Name
Click the Save As button in the lower left corner of the window.
In the Scene Save As... dialog box that opens, type a descriptive name in the Scene Name text box.
Click the Ok button to confirm.
Scene Save as... panel Context Menu
Right-click in the Scene Save as panel to open its context menu. Select from:
Rename: Rename the selected folder
Delete: Delete the selected folder
Create Sub Project: Create a new sub Project folder in the selected Project folder
Create Sub Folder: Create a new sub folder in the selected folder
Add to Bookmark: Add selected folder to Bookmarks
Delete from Bookmark: Delete selected folder from Bookmarks
Switch Folder Highlighting OFF/ON: Set highlighting of folders to ON or OFF. For example, if a folder (and sub-folders) contain a Scene it will be highlighted when the Scene tab is selected. This feature can also be set in User Interface of the Viz Configuration.
<Bookmark(s)>: Click on a bookmarked folder to select that folder
To Undo/redo Operations in a Scene
Click the Undo/Redo button in the lower right corner of the Scene Tree panel, or
Hold the pointer over the Scene Tree panel and press the keyboard shortcut <Ctrl+Z/Y>.
Tip: Holding the pointer over the Undo/Redo buttons will show a text in the status bar describing the action that is about to be performed. Also, operations can be undone/redone although the scene has been saved. However, this is not possible after the scene has been closed and reopened.
