MtTelestrator plug-in
The MtTelestrator plug-in is used to do telestration on a Container level (used with the GraffitiTex plug-in (added automatically to the same Container)).
For scene-wide telestration the MtSensor plug-in has a telestration feature.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> MultiTouchComp
MtTelestrator Configuration
Active: Select On (enable) or Off (disable) telestration input from the user.
Minimum Telestration Width: Minimum brush width to assign based on pressure applied to sensor.
Maximum Telestration Width: Maximum brush width to assign based on pressure applied to sensor.
Color: The color to assign for subsequent telestration drawing.
Id: To give additional context in the handler script, specify a string that will identify any notifications dispatched by this plug-in. This is often included as an argument for the event so a common script may handle events from a number of plug-ins.
Set Shared Memory: If ON enables shared memory to be updated for the plug-in notifications.
Shared Memory Prefix: This sets a ‘prefix name’ to be prepended to the shared memory variables maintained by the plug-ins notifications. For plug-ins that maintain multiple fields each field name has the prefix prepended to it followed by a dot ‘.’ so as to mimic member access to an object, i.e: if the prefix is ‘Obj’ the fields ‘field1’ and ‘field2’ would be identified with the strings ‘Obj.field1’ and ‘Obj.field2’. The shared memory field ‘Obj’ is also maintained and is simply an integer that is modified every time any of its ‘subfields’ is updated.
Shared Memory Type: Click either Global, Scene, or Distributed. This selects the shared memory area to update.
Set Data Pool: Shows ‘you wish’ plug-in notifications to set a Data Pool variable.
Data Pool Variable: Shows the name of the Data Pool variable to have set.
Init: Clear current telestration and make Telestration active.
Clear: Clear the contents of the attached telestration.
Events and Notifications
The events dispatched by MtTelestrator are:
OnTelestrationStateChange (sent when telestration is activated or deactivated):
plug-inContainer as String
Id as String
TelestrationOn as Boolean
OnTelestrationColorChange (sent when telestration is activated or deactivated):
Id as String
PenColor as Color
OnTelestrationClear (sent when telestration is cleared):
Id as String
The shared memory field names are:
plug-inContainer: the name of the plug-ins container or ‘’ if attached to a scene
Id: the user ID string entered in the notification interface
PenColor: the current pen color
Active: 1 if telestration is active, 0 if not
MtTelestrator:
string plug-inContainer
string Id
string PenColor
string Active
To Create a Simple Scene with Telestration
Note: If a touch screen is not available then go to Viz Configuration and set Multi Touch input to Mouse
Create a new Scene.
Add a new group Container.
Add a Rectangle Geometry to the Container.
Add the MtTelestrator plug-in to the container. This automatically adds the GraffitiTex plug-in to the container.
Set the Active parameter for the MtTelestrator and GraffitiTex to ON in the Properties Panel.
Open the Scene in On Air. Use the touch input device to create freehand drawing.
Use the MtTelestrator and GraffitiTex plug-in editors to modify the telestration affect as required.
GraffitiTex plug-in
