Cog Wheel
Use this plug-in to create a cog wheel. It has a range of properties to adjust the look of the cog wheel.
To avoid decreasing the system performance, set the tessellation to a lower value since it does not make much difference in quality.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Cog Wheel Properties
Use LOD enables/disables dynamic level of detail.
Tesselation sets the level of detail.
Corners sets the number of corners the cogwheel is to be constructed of. The cog wheel gets one tooth for each corner, so the number of teeth changes correspondingly.
Height sets the height or width of the cog wheel.
Tooth height sets the height of the cog wheel teeth.
Diameter sets the diameter of the cog wheel.
Hole creates and sets the size of a hole in the cog wheel.
Bevel sets the degree of bevel at the cog wheel.
Inner Bevel enables or disables bevel in the cog wheel hole.
Show Top enables or disables visualization of the top.
Show Bottom enables or disables visualization of bottom.
Center allows you to select where the geometrical centre should be placed on the cog wheel, either Center, Bottom or Top.
To Create a Cogwheel
Add the Cog Wheel plug-in to a container.
Add a material to the same container.
Set Hole parameter to 50.0.
Set the transformation parameters for the container to:
Set rotation X: 90.0, Y:45.0 and Z: -45.0.
