MultiTouch plug-ins
The following Scene plug-ins are located in the MultiTouchComp folder:
All the MultiTouch plug-ins Container plug-ins require the MtSensor plug-in to be available. If a MultiTouch plug-ins Container plug-in is added to a Scene it will automatically add the MtSensor plug-in to the Scene if it is not there.
The plug-ins in this folder are inactive by default. To view the folder and use the plug-ins, set all plug-ins to active in plug-ins (see Viz Configuration in the Viz Engine Administrator Guide).
