Scatter Chart
This plug-in draws a scatter chart, filled with data out of a Shared Memory Map. You can use delimited strings or arrays for data transfer via Scene-, Global- or Distributed-Shared Memory.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> VisualDataTools
Scatter Chart Properties
Shared Mem.: Changes between Scene-, Global- and Distributed-Shared Memory. Use Inactive memory to not forward any values via Shared Memory
Key DataX: Shared Mem. key name for X values. DataX is the default input parameter for X values
Key DataY: Shared Mem. key name for Y values. DataY is the default input parameter for Y values
Key DataZ: Shared Mem. key name for Z values. DataZ is the default input parameter for Z values
Transfer Mode: Sets string- or array-based data transfer
Data Delim.: Defines the value separator sign(s)
Number Format: Defines if Viz should get the decimal point separator from the System Locale or Custom settings. If Custom is enabled,
Decimal Symbol: Defines which symbol is used as decimal point when Custom Number Format is set.
DataX, -Y, -Z Fit: Enables data normalization
DataX, -Y, -Z Scale: Scales input by the selected factor
DataX, -Y, -Z Offset: Adds an offset to the incoming data
DataX, -Y, -Z Auto Scale: Enables automatic data normalization
DataX, -Y, -Z Detect Limits: Detects minimum and maximum of all values and scales them to adjusted Start and Stop
DataX, -Y, -Z Threshold: Adds a definable offset to the detected limit
DataX, -Y, -Z Start: Lower Auto Scale edge
DataX, -Y, -Z Stop: Upper Auto Scale edge
Data Animation: Set the animation type to be created when data change is detected:
Disable: No animation
Timer: Create data transition animation (from an old set of data to a new set) within the specified time set in Duration sec.. Also select an Animation Mode
Director: Create data transition animation with the Stage Director, that controls the Animation Progress parameter from 0.0% (old data) to 100.0% (new data). Also select an Animation Mode
Animation Mode:
Concurrent: All nodes change concurrently
Left to Right: Transition from left to right
Right to Left: Transition from right to left
Balance Speed: Set to On, when Animation Mode is set to Left to Right or Right to Left, and the position of transformed data will be related to node values as well
Example:Balance Speed: If the values of four nodes change from 0,0,0,0 to 1,9,90,900 in Left to Right mode at 50% of the transformation. Balance Speed Off: Only the first two nodes will be transformed to new values. Balance Speed On: The first three nodes are already transformed to new values, and the last node also transformed to 44% of the new values, because the data change from 0 (0+0+0+0) to 1000 (1+9+90+900), at 50% of transformation (in this case the values is changed for 500 of 1000), the first 3 nodes are already finished and the last node is changed to 400
Durationsec.: Set the duration of the animation in seconds for Timer mode
Horizontal Alignment: Sets horizontal orientation to left, center or right
Chart Width: Adjusts the chart width
Container: Drag drop the container which will be used for the scatter nodes
DataZ Position: Use DataZ for Z-axis positioning
DataZ SizeX: Z Values influence X scaling
DataZ SizeY: Z Values influence Y scaling
DataZ SizeZ: Z Values influence Z scaling
Center Container: Centers each translated container
Fit Width: Considers the width of the scatter node containers which means that the containers do not reach outside of the specified range
Animate Position: Sets the translation type: None: no animation, Y: animates the container along the Y axis (suggestion: Scale Y + DataLabel for BarChart alike labeling)
Animate Scaling: Sets the scaling type: None: no scaling at all, XYZ: linear scaling in all directions, Y: scales in y direction only (->BarChart)
Relative Length: If activated, each scatter node will have its own 100% size (e.g. 7 nodes equal 700%)
Const. Speed: Sets the same animation duration for each bar
Total Length%: Sets the accumulated size of all scatter nodes in percent
To Create a Scatter Chart
Create a group and add the Sphere plug-in to it.
Open the transformation editor and set the Scaling (locked) to 0.2.
Add a material and/or a texture to the sphere.
Set the group with the sphere to hidden.
Create a new group and add the Scatter Chart plug-in to it.
Open the Transformation Editor and set Position X and Y to -100.0.
Open the Scatter Chart editor and set the following parameters:
Set the following DataY values: 10,20,30,20,50,60,80,45,20.
Set Width to 250.0.
Drag and drop the container with the Sphere to the Container placeholder.
