Text FX Vertex Explode
The Text FX Vertex Explode plug-in allows you to create an effect where text characters are exploded with a vertex effect.
Text FX Vertex Explode Properties
X, Y and Z Distance: Defines direction and distance of moved text.
Show Direction: Enables and disables view of ‘movement’ vector.
Note: The direction will not be shown in On Air mode.
