Version 4.1 | Published July 09, 2021 ©
Configuring the MSE Playlist Panel
The MSE Playlist panel is presented on the Viz Mosart UI, offering users active (touch or click-sensitive) thumbnails of graphics held on an MSE.
Setting User Access to MSE Playlist Panel
The Viz Mosart UI needs a connection to MSE. You must configure or change an existing MSE host to activate the MSE Playlist panel.
Open Viz Mosart ManusAdministrator console window
Type settings
Navigate to the Viz Media Sequencer configuration.
Modify the value of Mse host.
Restart the console.
Note: If the MSE Playlist panel is visible in the Viz Mosart UI, you can add the host address of the Media Sequencer directly. Both computer name and IP can be used.
The MSE Playlist Panel can be hosted as a floating window or as a docked window in the Viz Mosart UI.
This is controlled with View > Floating windows > Playlist Panel.
