Version 4.1 | Published October 29, 2021 ©
AV Automation Devices Virtual Set
Virtual Set: Check to enable virtual set control.
Virtual Set: BRAINSTORM.
Connection string: Server=hostname; [port=portnumber;] [mode=mixmode;].
Connection String Parameters
Server: IPaddress or network name of machine where Viz Tracking Hub is running. Required.
Port: tcpip port Viz Tracking Hub accepts connections. Optional.
Default value is 20000. -
LocalIP: IPaddress of local network interface. Optional. Default value is first Ethernet interface.
Router: Router name configured in Viz Tracking Hub. Optional.
Default value is first router in Viz Tracking Hub.
Sample Conenction string: Server=10.45.0.15;Port=20000
Camera set index enumeration starts from 1. This means that if a router has two camera sets configured, they indices will be 1 and 2.
Known Issue: Driver cannot detect when hub server is going offline. For example, if you kill the server, the driver keeps sending messages to server without an error being raised.
