Audio Mixer Configuration Files
Calrec TCP/IP Configuration File
The Calrec TCP/IP configuration file is named AudioMixerCalrec.xml.
xml
version
"1.0"
encoding
"utf-8"
DeviceConfig
name
"AudioMixerCalrec"
Properties
<!-- If set to true, controller stays connected when in idle. Note that in a redundancy setup,on both main and backup Viz Mosart servers this option must be set to false. -->
item
name
"ConnectedWhenIdle"
value
"false"
<!-- If set to true, AvAutomation waits for Ack after sending command to the driver.
Note that this configuration will overwrite the general configuration with same name from AvAutomation settings (Ctrl+Shift+S).
If commented, the general configuration from AvAutomation will be taken into consideration.-->
item
name
"AudioWaitForAck"
value
"true"
<!-- Max wait time for receiving Ack -->
item
name
"AckTime"
value
"199"
<!-- Wait time before trying to reconnect -->
item
name
"ConWait"
value
"1000"
<!-- Interval to set fader levels on the audio driver. If set to 0, the operation will not be re-scheduled.
If commented, the genral configuration from AvAutomation will be taken into consideration.-->
item
name
"AudioPollInterval"
value
"0"
<!-- Interval to send an heartbeat to the driver (number of counts until next heartbeat will be sent). Set this to -1 to disable sending the heartbeat.
In this case, AvAutomation will not be able to detect when audio driver connection goes down, for example. -->
item
name
"HeartbeatInterval"
value
"1000"
Properties
DeviceConfig
SSL Configuration File
The SSL configuration file is the same as used for Calrec TCP/IP Configuration File.
