AV Automation Devices Audio
Viz Mosart can connect to a variety of audio mixers from several manufacturers.
From the Audio tab, the Audio Mixer, Sound player and Loudness settings can be configured, on a per-device basis.
AV Automation handles the following audio alternatives:
Audio Mixer, a backup audio mixer.
Sound Player, an internal Viz Mosart component
Loudness Control from Junger.
Audio Mixer
Use Audio mixer: Enables the audio mixer functionality.
The screenshot above is a for a midi mixer. Depending on which audio mixer is selected, the menu will display different fields. All fields are described below.
Audio Mixer Types
Audio mixer |
Protocol |
Supported hardware |
Interface |
Calrec |
RAP |
RS-422, TCP/IP (Artemis) |
DHD |
DHD RM4200-D v2.02 |
TCP/IP |
EUPHONIX |
RAP |
COM |
LAWO RMNOPL |
RemoteMNOPL |
Lawo mc² |
TCP/IP |
LAWO ZIRKON |
RAS, Lawo Zirkon subset |
MIDIMIXER |
Sanford.Multimedia |
MIDI |
SSL |
Light Broadcast Automation protocol, SSL Broadcast Automation Control Specification – v1.0 |
RS-422 or TCP/IP |
STAGETEC |
Stagetec Diamond RAS protocol, Monitora RAS |
COM |
STUDER_3000 |
Monitora + Ember, Ember 1.0 |
Studer OnAir 3000 |
RS-232 or TCP/IP |
STUDER_VISTA |
Ember |
Studer Vista |
TCP/IP |
VIZENGINE |
n/a |
Viz Opus only |
TCP/IP |
WHEATSTONE |
Wheatstone Mixer Automation Protocol v.1.4 |
TCP/IP |
YAMAHA_O2 |
MIDI |
Yamaha 01V96, DM1000, DM2000, DME64N, O2V96, LS9, CL5 |
MIDI |
vizrt-ips |
NewTek |
Vizrt Group/NewTek ip series mixers. TriCaster, VMC, Viz Verdi, Viz Vectar |
TCP/IP |
Serial (Calrec, Lawo, Studer, etc.): Serial port connected to the audio mixer (when Serial radio button is selected).
TCP/IP: Hostname (or IP address) and port to communicate with the audio mixer (when TCP/IP radio button is selected). Note that for Calrec it is possible to configure a main and backup audio mixer by specifying two comma separated hostname values and port values.
Backup hostname and port (LAWO RMNOPL): Hostname (or IP address) and port to the backup audio mixer console.
Set user labels on console: When selected, user labels on the Lawo or Vista console are overwritten.
MidiCh (MIDIMIXER and YAMAHA_O2): MIDI channel assigned to the audio mixer.
Midi Input port (MIDIMIXER and YAMAHA_O2): System MIDI input port to communicate with the audio mixer.
Midi Output port (MIDIMIXER and YAMAHA_O2): System MIDI output port to communicate with the audio mixer.
Default fade time: Time in frames for fading open faders with the manual fade function (CTRL+F).
Default snapshot: Snapshot to recall when starting the automation (MIDI parameter change).
Audio effect server: Name for the Audio effect fader. This fader will open if effect transitions are used.
Send reset command on connect: Used for STUDER3000 SW 2.2, or lower. Recalls a default setup for the Mixer panel.
Visible audio faders: Maximum visible faders in AV Automation.
AV Automation Audio Mixer Availability Table
Serial |
TCP/IP |
MidiCh |
Midiport |
Hostname |
Port |
Backup |
Backup |
Faderinput |
Useember |
Comport |
CALREC |
x |
x |
x |
x |
x |
DHD |
x |
x |
x |
EUPHONIX |
x |
x |
LAWO |
x |
x |
x |
x |
x |
LAWO |
x |
x |
x |
x |
x |
MIDI |
x |
x |
SSL |
x |
x |
x |
STAGETEC |
x |
x |
x |
x |
x |
STUDER |
x |
x |
x |
x |
x |
x |
STUDER |
x |
x |
x |
VIZ |
x |
x |
x |
WHEAT |
x |
x |
x |
YAMAHA |
x |
x |
Vizrt |
x |
x |
x |
Loudness Control
Use loudness controller: Check the box to enable loudness control.
Loudness controller type: JUNGER T*AP.
Triggers/levels: Name of triggers or loudness levels, one for each line. These will appear in a tool-tip menu in the Template editor, and must correspond to the configuration in the loudness controller(s).
Channels: Fixed values. For Junger T*AP there are four stereo channels per host. Connections to the audio faders are configured in A/V Setup/Edit/Audio config/Loudness channel.
Host:port: Hostname or IP address and optional port number for each controller.
Note: If the root node name is different than T*AP the name must be set in the AVA configuration property JungerRoot .
Sound Player
Use sound player: Enables connection to the Audio Player.
Select from either the Mosart Sound File Player or Mosart Audio Player. -
Host: Hostname or IP address to the computer running the Audio Player.
Default directory: Directory for the audio files (on the Audio Player’s PC).
