Version 4.1 | Published October 29, 2021 ©
How to Set Up Audio Player
Install Audio Player, then start it.
Open AV Automation.
Go to Devices > Preferences > Audio > Sound player.
Check Use sound player and choose Mosart Audio Player.
Under Host write the IP address to the computer where Audio Player is running.
Under Default directory, write the folder path where the audio files are stored.
Restart AV Automation and check that the connection is green.
