ts_templateset
The table ts_templateset contains the template sets.
Name
Type
Allow Null
Description
ts_recno
integer
No
Primary key.
ts_ga_recno
integer
No
Foreign key referencing the corresponding gallery in the ga_gallery table.
Template sets belonging to the shared gallery (ga_shared=1) are by definition shared template sets. Shared template sets will be present in all galleries.
Template sets belonging to any other gallery are by definition private template sets owned by the corresponding gallery.
ts_name
varchar(64)
No
The name of the template set.
ts_global
smallint
Yes
(deprecated)
ts_description
varchar(128)
Yes
Optional template set description.
ts_ga_updating
integer
Yes
(deprecated)
ts_basedon
varchar(64)
Yes
Hierarchical template sets. Specifies the base template set, if applicable.
ts_hidefromuser
smallint
Yes
Non-zero (true) if the template set shall be hidden from users (i.e. from Mosart GUI and NCS presentations).
