Working with Audio
To Add an Audio Clip to a Scene (Context Menu)
Select the target Container.
Go to Plugins and find the Audio plug-in.
Right click the plug-in and select Add to Contianer. The Audio plug-in is added to the selected Container.
The audio needs to be added as animation into the stage, Click on the Stage Button.
Create a new Director or choose an existing Director.
Drag the container to the Director.
Right click on this channel and select Audio > Clip.
There are two ways to add an Audio Clip:
DB Clip: Select and drag an Audio Clip from the Asset view panel to the Clip drop box (2).
File: In the Clip line (3), click the
icon to select an Audio clip to use.
To Import or Export an Audio Clip
For information about how to import or export an audio clip from a hard disk or a network share to the database see Import and Archive.
