Stage Shortcuts
General
Function |
Key and/or Mouse Shortcut |
Shows Object Editor |
CTRL + 1 |
Shows Dopesheet View |
CTRL + 2 |
Shows Spline View |
CTRL + 3 |
Shows Dope/Spline View |
CTRL + 4 |
Stage Tree
Function |
Jumps to Top Container |
HOME |
Jumps to Last Container |
END |
Moves a page down in the tree |
PAGE DOWN |
Moves a page up in the tree |
PAGE UP |
Scrolls up the tree |
Cursor up |
Scrolls down the tree |
Cursor down |
Jumps to an item (Director, Actor, or Channel), in the tree |
Press the first letter of the item name |
Opens or closes the selected tree |
ENTER |
Stage Views
Function |
Starts/Continues Animation Forward |
SPACE |
Starts Animation Backwards |
SHIFT + ENTER |
Sets Time-line Marker/Value to Start |
CTRL + HOME |
Sets Time-line Marker/Value to End (not when infinity is selected) |
CTRL + END |
Sets View to 0 |
HOME |
Sets View to End director |
END |
Moves the Time-line Marker one field |
CTRL + the left or right arrow key |
Moves the Time-line Marker more than one field at a time |
Left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker five fields, left or right, and in 1080i60 the movement is six fields, left or right. |
ALT + LEFT ARROW/RIGHT ARROW. This, for example, in 1080i50 format, moves the time-line marker 50 fields, left or right, and in 1080i60 the movement is 60 fields, left or right |
Deletes Selected Key Frame(s) |
DELETE |
Pans View |
Middle mouse click and drag |
Zooms Time Axis In or Out |
Mouse wheel |
Zooms Time Axis to Selected Channel |
SHIFT + Z |
Zooms Time Axis to whole Animation |
SHIFT + X |
Zooms Spline/Dopesheet View In |
Mouse wheel |
Zooms Spline/Dopesheet View Out |
Mouse wheel |
Zooms Spline View to whole Spline |
SHIFT + A |
Zooms Time Axis and Spline View to view all Key Frames of selected Channel |
SHIFT + Q |
Zooms Time and Value Axis to View All Key Frames |
SHIFT + W |
Zooms Time Axis In/Out |
Z + Middle mouse click and drag |
Zooms Value Axis in Spline Editor In/Out |
A + Middle mouse click and drag |
Copies Selected Key Frame |
C + Left mouse click and drag |
Brings View to Time-line Marker |
M |
Reverses the Order of Selected Key Frames |
CTRL + R |
Snaps to Grid on/off |
CTRL + G |
Sets Time Axis to Seconds |
CTRL + 8 |
Sets Time Axis to Frames |
CTRL + 9 |
Sets Time Axis to Fields |
CTRL + 0 |
Moves Time-line Marker to nearest Key Frame |
J |
Scales a Portion of Selected Director |
T + Left mouse click on Director Bar |
Provides Rubber band Selection |
S + Left mouse click and drag |
Zooms in onto specific region |
Z + Left mouse click and drag |
Inserts a new Stop Point |
S + Left mouse click on Director Bar |
Views Spline 1 (Rotation Channel Only) |
CTRL + Z |
Views Spline 2 (Rotation Channel Only) |
CTRL + X |
Views Spline 3 (Rotation Channel Only) |
CTRL + C |
Jumps to next Key Frame |
TAB (a Key frame must be highlighted first) |
Jumps to previous Key Frame |
SHIFT + TAB |
Escapes from moving a Key Frame |
ESC |
