Asset View Shortcuts
The following shortcuts are valid for the Asset View:
Action |
Key and/or Mouse Shortcut |
Renames an item |
F2 |
Focuses on the search input field |
CTRL + F |
Copies the UUID of the item to the clipboard |
CTRL + U |
Copies the path of the item to the clipboard |
CTRL + SHIFT + U |
Checks in an item |
CTRL + I |
Adds a new scene or material (if the type is selected) |
CTRL + N |
Checks out an item |
CTRL + O |
References search on this item |
CTRL + R |
Exports file |
CTRL + E |
Zooms in |
CTRL + + |
Zooms out |
CTRL + - |
Copies |
CTRL + C |
Cuts |
CTRL + X |
Pastes |
CTRL + V |
Shows icon view |
CTRL + SHIFT + 1 |
Shows list view |
CTRL + SHIFT + 2 |
Selects all items |
CTRL + A |
Shows properties |
CTRL + P |
Duplicates file |
CTRL + SHIFT + V |
